Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Codybuts
Sep 13, 2019Aspirant
I even moved it right beside the doorway, came up blue with good backhaul, two mins later went to poor..try new firmware I guess.
I get better speed when it's the furthest point in my garage ? Both poor.
Edit I guess there is no new firmware everything is up to date must of been the new sat syncing..
Any help is greatly appreciated
Sep 13, 2019Guru - Experienced User
What happens if you place new SAT where SAT1 is and place SAT1 where new at is. Does SAT1 experience the same condition?
- CodybutsSep 13, 2019AspirantYes just spent another 2 hours on phone before had to leave for work resyncing and swapping satellites..
600 ish at router..4-500 at sat 1 and sat 2 highest 150, and it also seems wifi is intermittent..one minute I get 4-600 at router and then next every sat and router gets 20-30 even reconnecting device ..then a bit after it goes back..then back down ?
