Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Sep 13, 2019Guru - Experienced User
What happens if you place new SAT where SAT1 is and place SAT1 where new at is. Does SAT1 experience the same condition?
Codybuts
Sep 13, 2019Aspirant
Yes just spent another 2 hours on phone before had to leave for work resyncing and swapping satellites..
600 ish at router..4-500 at sat 1 and sat 2 highest 150, and it also seems wifi is intermittent..one minute I get 4-600 at router and then next every sat and router gets 20-30 even reconnecting device ..then a bit after it goes back..then back down ?
