Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Sep 15, 2019Guru - Experienced User
I believe this is a environement issue between the main building and the garage where sat 2 is. Again, buiding materials can effect wifi singnal and performance.
- CodybutsSep 15, 2019AspirantThanks for reply, it's actually issues between router and sat 1 .
Sat 2 usually shows good.
I am fidgeting with placement at the moment starting with sat 1 leaving for ten minutes each time.. waiting for a good. Will report back- FURRYe38Sep 15, 2019Guru - Experienced User
Does swapping RBS around show the same problem were SAT1 is place? Just seeing if any RBS placed where sat 1 is exhibits this same issue.
- CodybutsSep 15, 2019AspirantMy router is actually back to the internet not working until resetting my modem .
What is the Mfr and model# of the ISP modem?
