Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Sep 15, 2019Guru - Experienced User
I would let the system settle in and check in about a day or so. Seen it where the UI reports and refreshes the data over a period of time.
Codybuts
Sep 15, 2019Aspirant
It hasn't disconnected at the moment but I don't have any satellites plugged in
- FURRYe38Sep 15, 2019Guru - Experienced User
Ok..maybe enable just 1 satellite.
- SW_Sep 15, 2019Prodigy
Codybuts ,
If you are able to access your Orbi, can you post the result from this page? Replace the IP address (192.168.1.1) with your Orbi IP address. This will tell us the status of your Backhaul signal strength, which is not to be confused with backhaul status on the Orbi UI.
- CodybutsSep 15, 2019Aspirant
ext_dev_info = [{ "mac address": "78:D2:94:AE:FE:83", "ip address": "192.168.0.39", "module name": "RBS20", "serial number": "5EK2875M0061C", "signal strength": "-68", "current version": "V2.3.5.26", "backhaul status": "2", "device name": "Orbi Satellite-1" }, { "mac address": "28:80:88:EA:BA:C1", "ip address": "192.168.0.239", "module name": "RBS20", "serial number": "5DL8915W042F1", "signal strength": "-85", "current version": "V2.3.5.26", "backhaul status": "3", "device name": "Orbi Satellite-2" }] ; ext_check_info = [ { }, { "mac address" : "28:80:88:EA:BA:C1", "ip address" : "192.168.0.239", "module name" : "RBS20", "device name" : "RBS20", "check status" : "006", "current version" : "V2.3.5.26", "new version" : "0", "release note" : "", "duration" : "90", "fw download folder from router" : "V2.3.5", "fw download version from router" : "V2.3.5.26", "fw download url" : "https://http.fw.updates1.netgear.com/rbs20/V2.3.5/ww" } ] ; ext_upg_info = [ { }, { } ] ; base_check_info = {"current version": "V2.3.5.26", "new version": "0", "check status": "000"}; base_upg_info = {"upgrade status": "0"}; base_url_status = {"url status": "000"};
is -68 good for sattelite 1 ?
