Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Codybuts
Sep 15, 2019Aspirant
Getting speeds of 105 or so in my garage now.
Router basement front of house
Sat 1 basement back or house ( in window cil pointing garage )
And sat 2 just inside garage door.
Can live with these speeds as long as it stays online.. which it isn't .
- SW_Sep 16, 2019Prodigy
Codybuts ,
Satellite-1 backhaul signal strength at -60dBm is ideal, but Satellite-2 backhaul signal strength at -72dBm isn't usable. Try moving Satellite-2 around to get better signal strength first. It needs to be higher than -70dBm, ideally between -60dBm to -67dBm.
Codybuts ,
Given your current satellite-2 signal strength at -72dBm, enabling fast roaming, daisy-chain, and short preamble will be a bad combimation. You can come back to tweak these settings after relocating satellite-2 to get usable backhaul signal strength.
- FURRYe38Sep 16, 2019Guru - Experienced User
I recommend getting the RBR and RBS out of the basement and up to the 1st or main floor. Basements are not good for wifi.
