Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Codybuts
Sep 19, 2019Aspirant
Sent out today pretty sure I won't get it til Monday though.
After monitoring further it seems to disconnect 3-6 times a day , after about a half hour everything is back online
- FURRYe38Sep 19, 2019Guru - Experienced User
Glad your getting something though.
Might revert back to a prior router setup if you still have one while you wait for the RMA to arrive.
- CodybutsSep 19, 2019AspirantYeah would be the modem router from my isp, but it just doesn't reach far for wifi and we watch Netflix and such farther from the modem router so I'd rather use the broken orbi for now lol.
Thanks for the reply. This is frustrating- FURRYe38Sep 19, 2019Guru - Experienced User
Understandable. However i'm glad NG is stepping up and sending you a new system for you to try out. Hoping that it will resolve this for you and you just had bad system.
