Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Codybuts
Sep 23, 2019Aspirant
Weirdest thing.
I took bridge mode off cause it knocked out my tv and clearly didn't make a difference.
In turn it turned ISP wifi back on.
I changed my ISP wifi to match my orbi wifi, and I haven't had any disconnects in 24 hours or so.
Not sure what to think of this at the moment
- FURRYe38Sep 23, 2019Guru - Experienced User
So your using ISPs wifi as well as Orbis wifi?
- CodybutsSep 23, 2019AspirantCorrect, both 2.4 and 5g on ISP and orbi are both set to the same ssid and pw.
I just haven't really tested speeds throughout, I'd imagine would be fine.. although sat 2 still only see 130 Mbps where sat 1 I see almost same as router around 500- CodybutsSep 23, 2019AspirantSeems now it will disconnect for like a minute ? And reconnect itself.. notciedt while watching Netflix, it buffered for like 20 seconds , also my cameras flashed off and then back on...
Weird..
