Codybuts
Sep 08, 2019Aspirant
Slow Satellite 2 Speeds
Hello, one more issue to resolve. I get wifi speeds of 4-600 beside router, and beside sat 1. Beside sat 2 I'm only seeing around 100 sometimes 120 ish. Is this normal? Should the full speed ...
Sep 23, 2019Guru - Experienced User
So your using ISPs wifi as well as Orbis wifi?
Codybuts
Sep 23, 2019Aspirant
Correct, both 2.4 and 5g on ISP and orbi are both set to the same ssid and pw.
I just haven't really tested speeds throughout, I'd imagine would be fine.. although sat 2 still only see 130 Mbps where sat 1 I see almost same as router around 500
- CodybutsSep 23, 2019AspirantSeems now it will disconnect for like a minute ? And reconnect itself.. notciedt while watching Netflix, it buffered for like 20 seconds , also my cameras flashed off and then back on...
Weird..
