SimonP71
Sep 23, 2022Aspirant
Slow speed on RB50 on BT FTTP 900
Hello all, I am wondering whether anyone can shed some light on why my Orbi router only achieves speeds of around 460 mbps when connected directly to the BT open reach box on my wall when the hom...
KevinLiT
Sep 23, 2022NETGEAR Moderator
Hello SimonP71,
Welcome to the NETGEAR Community!
I understand that you are having speed issues with your RBR50. Try changing the channel settings on your RBR50 to improve your network speed. The best practice is to use channels 1,6 or 11 for your 2.4Ghz network band and 36, 40, 44, or 48 for the 5Ghz network band.
To change the network channel on your RBR50 please follow the directions below:
- Navigate to Orbilogin.com
- Select Wireless
- Select "channel menu"
- Select desired channel
Best,
Kevin
Community Team
- SimonP71Sep 23, 2022AspirantHi. Thanks for the reply.
Speed test when Orbi plugged into BT Home Hub in AP mode = 900 Mbps. Speed test when BT Hub removed and Orbi set to Router mode and plugged in directly, drops to 460 Mbps.
It is not a wireless channel problem as far as I can tell. The speed test is performed at router level not by a connected device. I could for example login remotely and get the router to perform a speed test. The result is the same only around 460Mbps when the Orbi is set to router mode. When connected to BT Hub in AP mode speed test = 900+ Mbps.
Strange !- KevinLiTSep 23, 2022NETGEAR Moderator
Hello SimonP71,
The network channels currently used by your Orbi could be congested in your area. Congested network channels result in result in slower speeds. When the Orbi is in AP mode it does not use router capabilities. In your case, when your Orbi is not using router capabilities the speeds are 900Mbps. However, when you change the mode on your Orbi from AP mode to router mode the speeds slow down. This could be the result of a configuration error due to network congestion.
I noticed that your RBR50 is on firmware version 2.7.3.22. Please update your RBR50 to the current firmware version which is 2.7.4.24 at this time.
Please navigate to the link below to download the current firmware version 2.7.4.24 for your RBR50:
https://www.netgear.com/support/product/RBR50.aspx#download
Best,
Kevin
Community Team
- SimonP71Sep 24, 2022Aspirant
Thank you for your help so far. I have updated the firmware. For some reason, the Orbi app said it wasn’t available, so had to sort hat manually. I am now the most recent.
I have changed the channels for 2.4 and 5ghz to what you suggest, but speed tests are the same 460Mbps.
I’m at a loss with this to be honest.
- FURRYe38Sep 24, 2022Guru - Experienced User
Are you testing speeds with a wireless device or a wired device. You should be seeing near 900Mpbs with a ethernet connected PC if it's connecting at 1000Mbps to the back of the router after a reset and setup from scratch. Don't enable Armor, Access Controls, Circle or Traffic Meter. Don't use a saved backup configuration file.
Wireless device, you'll not see much over 300-500Mpbs on 5Ghz AC due to limitations of devices and connections rates at 80Mhz seen here. Nature of this beast.
- SimonP71Sep 25, 2022AspirantHello. Thanks for the reply. No I am not testing via wireless. I understand the limitations of wireless connections.
I am testing at router level, using the Orbi router connected directly to fibre. I am running the speed test via the router option.
