SimonP71
Sep 23, 2022Aspirant
Slow speed on RB50 on BT FTTP 900
Hello all, I am wondering whether anyone can shed some light on why my Orbi router only achieves speeds of around 460 mbps when connected directly to the BT open reach box on my wall when the hom...
SimonP71
Hi. Thanks for the reply.
Speed test when Orbi plugged into BT Home Hub in AP mode = 900 Mbps. Speed test when BT Hub removed and Orbi set to Router mode and plugged in directly, drops to 460 Mbps.
It is not a wireless channel problem as far as I can tell. The speed test is performed at router level not by a connected device. I could for example login remotely and get the router to perform a speed test. The result is the same only around 460Mbps when the Orbi is set to router mode. When connected to BT Hub in AP mode speed test = 900+ Mbps.
Strange !
Strange !
KevinLiT
Sep 23, 2022NETGEAR Moderator
Hello SimonP71,
The network channels currently used by your Orbi could be congested in your area. Congested network channels result in result in slower speeds. When the Orbi is in AP mode it does not use router capabilities. In your case, when your Orbi is not using router capabilities the speeds are 900Mbps. However, when you change the mode on your Orbi from AP mode to router mode the speeds slow down. This could be the result of a configuration error due to network congestion.
I noticed that your RBR50 is on firmware version 2.7.3.22. Please update your RBR50 to the current firmware version which is 2.7.4.24 at this time.
Please navigate to the link below to download the current firmware version 2.7.4.24 for your RBR50:
https://www.netgear.com/support/product/RBR50.aspx#download
Best,
Kevin
Community Team
