Andylaugh's avatar
Andylaugh
Follower
Dec 19, 2019
Slow speeds Dm200 with Rb50
I have a DM200 Muden into a Orbi rb50.
The speed coming into the modem is 50mbps yet the speed at the Orbi is only 32mbps.
Any ideas?
1 Reply
  • FURRYe38's avatar
    What mode is your modem working in? Router or modem only mode?
    Modem Combo Units:
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Are you testing wired or wireless speeds? Wired is preferred first.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
