Jagan
Sep 13, 2017Aspirant
Slow speeds on WiFI
Hi, Got Orbi few days back very happy with the coverage even upgraded to the latest firmwarie which was release today. Using 100Mbps Fiber connection from my PC to Orbi thorugh LAN which...
Ely
Sep 16, 2017Luminary
It seems to me you might have some kind of interferance going on since two totally different Wi-Fi systems are having the same issue, hopefully your new unit will not experience it. I would advise you however to try using different broadcasting channels on both the 2.4GHz and 5GHz frecuencies, also look out for other devices on your network that might be causing interference or have their own created networks ie: Soundbars, DVRs, Microwaves etc, try shutting them off and see if the speed improves, you might need to restart your Orbi while the other devices are off when you try this
Jagan
Sep 16, 2017Aspirant
Yes thanks for the advice waiting for replacment to arrive so I can test it again. Here not using any other devices in the pc room apart from my logitech G933 & Xbox wirlesss dongle.
Will get back to this post after furuther testing
