Jagan
Sep 13, 2017Aspirant
Slow speeds on WiFI
Hi, Got Orbi few days back very happy with the coverage even upgraded to the latest firmwarie which was release today. Using 100Mbps Fiber connection from my PC to Orbi thorugh LAN which...
Jagan
Sep 17, 2017Aspirant
Just wanted post the update regarding the issue now my replacment Orbi has arrived
Tested it with default firmware speed was more are like same 20-40mbps
So updated both Router/Satellite to latest version V2.0.0.72. Looks like this have fixed the issues, Now on speedtest seeing speeds like 85-95mbps, Even near the Satellite which is like 35 feet away from my router also giving similar speeds.
So just wanted to ask one question. So I need to do a factory reset of both Router/Modem now after upgrading the firmware is this a must?
Thanks
Ely
Sep 17, 2017Luminary
If it ain't broken, don't fix it, that's my opinion, I have never done a factory reset after upgrading firmware and I have never experienced any issues, anyway if you still decide to do it, remember to backup your configuration in settings so you don't have to re-do the whole thing again, but if I was you I wouldn't do a factory reset, only do that when you have issues you can not normaly fix.
- JaganSep 18, 2017Aspirant
Thanks sir for the advice. Will keep using this as of now without doing a factory reset
- georgenganSep 18, 2017Star
You can consider using freeware version such as NetSpot to check which wifi, channels, and strength are surrounding ur environment before you decide which channel to switch on your Orbi router. I find this step to be very useful in choosing the optimal channel.
