oohtruck
Mar 25, 2017Initiate
Slow speeds/connectivity issues
I've been using my RBR50 for a few months now without any issues but in the last week I've started experiencing extremely slow speeds, if not complete disconnection in my bedroom, which is maybe 24-3...
ricblue
Mar 26, 2017Tutor
I'm having very odd, similar issue
My wife's iMac (Latest Mac OS Sierra, all updates, 21.5", Mid-2011, 2.5GHz Intel Core i5) was until last week connecting at 300 Mbps to the Orbi Satellite sitting 6 feet away. It only has a 802.11n card so 300 Mbps is the max I can expect but that was enough to deliver full 101 Mbps of our Optimum plan to the iMac.
TODAY - the iMac will only ever connect at 144Mbps to the Orbi Satellite, sitting in the same place, 6 feet away. No changes in location of either device.
I have logged into the Satellite to confirm that the iMac is connecting to the correct near-by Orbi
Speedtest (which tested 101+ Mbps last time i tested) is now reporting only reporting 35-50 Mbps downstream to the iMac so the 144 vs 300 Mbps to the Orbi is the new bottleneck.
VERY FRUSTRATING -- wife reporting that her Mac "feels slow"
I've done "forget this network" / re-pair to the wifi on the iMac - doesn't help
Orbi and Satellite update recently to v1.8.0.6 -- is there a problem with this firmware version???
iMac reports good signal strength so why only 144 Mbps???? --- RSSI = -20dBm, Noise = -90dBm, MCS Index = 15, BUT Tx rate = 144Mbps (and never higher)
st_shaw
Mar 26, 2017Master
ricblue wrote:I'm having very odd, similar issue
-20 dBm is a crazy strong signal. It could be overdriving the receiver on the Mac. Try moving the Orbi farther from the Mac and/or reducing the output power of the Orbi. More power is not necesarily better with WiFi. I'm seeing -48 dBm 8-ft away from Orbi on 5 GHz.
- haydomMar 26, 2017Initiate
I'm having similar problems. The firmware 1.8.0.6 seems to be causing a problem of connection - especially to ipads/iphones but also android smartphones. I've tried to manually update back to the older firmware 1.5 but the system seems to automatically update back to 1.8 after I've done this...
Any advice is highly appreciated!!! I just recently purchased the Orbi Ac3000 - and I'm getting a lot of flak from the family now:-)... hope to hear some positive news on new firmware solving this issue etc....
- oohtruckMar 27, 2017Initiate
Upon further investigation, my problem is isolated to my tablets as well. I'm also on 1.8.0.6
- DarrenMMar 29, 2017Sr. NETGEAR Moderator
You could try to lower the power level of the 2.4ghz network in the advanced wireless settings some people have said this has helped the issues.
DarrenM
