IrishNick
Nov 14, 2017Follower
Slow throughput Orbi
Hi, I’m struggling with slow wifi speed and would welcome any help please. I have a modem/router supplied by my ISP which works great (250MB) in close proximity, but has limited Wifi range, hence t...
rebel_orbi
Nov 16, 2017Tutor
I have the exact same problems with a brand new Orbi RBK50.
I've have done the enable and disable beam-forming and Mu-MIMO.
I have a gigabit service, QoS shows 400ish speedtest.
I can't get past 20 Mbps on WiFi.
Orbi is in Access Point mode since I have an R7000 as main router.
rebel_orbi
Nov 18, 2017Tutor
So I updated the firmware and played around with the channels once more.
Called support, they said updating channels takes 24 hours to register, a reboot doesn't phase it, not sure why?!?
I'm not sure why whenever I test with speedtest.net I see speeds around 35-40 Mbps, but when I use those same devices to test on fast.com I see around 375-450 Mbps...
I had two blips yesterday when the speedtest.net result came back at 426 Mbps, and I have yet to see it again....
All testing is being down in the same room with the Orbi router, which is wired directly with Cat5E run to the R7000 (WiFi) disabled.
Wired test through Orbi Lan ports shows 900 Mbps.
