GB_NET
Apr 19, 2019Aspirant
Slow upload speeds with Orbi RBR50
If I run the speedtest from the QoS Setup page in the Orbi admin console, I get:
Download: 90.56 Mbps
Upload: 41.27 Mbps
If I run speedtest from my wirelessly connected Surface Pro laptop I get...
GB_NET
Apr 22, 2019Aspirant
Thank you for your suggestions.
The firmware level is 2.3.1.48.
The modem is an Arris CM8200.
The distance between the router and satellite is just under 30 ft.
I've tried with two laptops. Both have been about 10 ft from the router (40 ft from the satellite).
I'm using Auto and 36. I've also tried channels 6 and 48 but this made no difference.
My laptops both use the 5 GHz channel.
I've used Acrylic to take a look at the channels being broadcast and I don't see any issues with neighbors etc. My channels dominate.
WPA2-PSK is configured.
As I said, the download speeds using speedtest.net on the laptops match with that reported by the router under the QoS settings so I would think that the wireless connections are fine.
I might try the advanced settings you suggested when I get a chance.
I would like to understand the upload speed discrepancy. This would help determine if there's a solution.
GB_NET
Also, does anyone know if you can determine or specify which server the router uses for the speedtest?
