randomguywarwic
Aug 10, 2020Aspirant
Slow web browsing - pulling my hair out! RBK53 **Help**
Hi All - I installed the above Orbi router and 2 sataligts in my bungalow. They are in direct line of sight, R/S/S about 10m apart. Have the router connected to a Archer MR200 4g router (via network cable) in the loft space. I have a wired connection to my sons gaming PC to the router, along with a wirec connection to my NAS drive on the satalite 2. I have about 15 wireless devises.
Running the latest firmware...
I get about 20mb down 8mb up. (Wishing BT/Cable would give me real internet!)
Before buying the orbi, I ran several routers (netowrk in a netowrk) to get house hold coverage, and things ran well. but having 4 different wireless networks was giving me pain as people moved around the house, so incomed Orbi!
I have set this thing up every possible way... As A router, (using the 4g router in bridge mode) I have tried in AP mode so the 4g router runs DHCP. I have tried every rotations on MIMO. Beamforming, daisy chain on and off - MultiMedia on and off. I have tried different DNS Ip addresses, bit ihave this crazt problem, that website seems to take an AGE (Sometimes 20 seconds of more) to load.... Whats funny is, that every device connected through the Wifi, has this issue.... My sons PC that is lardwired to the router, runs fine!!! Its reached a pint where the wife and kids are saying send it back... but i cant believe something this powerful (And Expensive) it must be. asetting somewhere... Any Ideas??? I readom somehwere about QOS, but i cant seem to access the page i have seen in other forums!
Thanks! - frustrated in warwick!
- MstrbigMaster
I have the exact same RBK53 system. When I set mine up, I followed the textbook install through the app. Then I turned on MIMO, Beamforming, daisy chain and QOS. My speeds are incredible.
You say you had multiple switches and routers throughout the home? Can you wire your satellites, as there may be too much interference between the Orbi RBR50 and the RBS50 satellites. My system is wired backhaul because there is some distance between each node.
- randomguywarwicAspirant
Thanks for the feedback - I did the set up the same... I have removed all the other Wifi switched and routers and even switche of th wifi from the main 4g router to reduce any interference... Hard wiring the Satalights may not be a bad idea, ad i could put them all in the lift. In theory though, i shouldnt need to... Everything on the app is green and good... When i say ots slow, The HD TV streams well, and my son is playing his online games at the same time with no issue, the problem is just when you open an internet browser to surf the web, there is a lag, (big lag) for pages to open.... sometimes you can waite ages, hence with i looked at the DNS... Its just odd that it doens occir on the PC thats hard wired to the router.... I only have 1neighbours so its not like there is any traffic interefering...
When you say you set the QOS, How exactly did you do this? I can the tick box for multimedia streaming, but cant find anying on QOS..... anywhere!
Mstrbig wrote:I have the exact same RBK53 system. When I set mine up, I followed the textbook install through the app. Then I turned on MIMO, Beamforming, daisy chain and QOS. My speeds are incredible.
- MstrbigMaster
Maybe tthe browser needs refreshing or maybe the PC is just not getting a good WIFI connection. Check your WIFI channels to make sure you are on an optimum channel with less traffic. If I remember correctly your internet speed is slow to start with. That can play a huge role when other devices are using the same bandwidth.
QOS = orbilogin.com - advanced - wireless settings - "Enable WMM (Wi-Fi multimedia) settings"
