Endurs
Jun 11, 2018Follower
Slow WiFi - Orbi RBR20
Good Evening,
I recently purchased an Orbi AC2200 from Costco. Model number is RBR20. The router itself gets around 350 mbps (on a 400 mbps connection), but nothing else gets over 15 mbps. I...
Jun 12, 2018Guru - Experienced User
What wireless devices do you have connected?
Are they connected to the 5Ghz portion of the Orbi?
How are you speed testing?
Do wired LAN cable connections see better results?
