Endurs
Jun 11, 2018Follower
Slow WiFi - Orbi RBR20
Good Evening,
I recently purchased an Orbi AC2200 from Costco. Model number is RBR20. The router itself gets around 350 mbps (on a 400 mbps connection), but nothing else gets over 15 mbps. I...
Aug 11, 2018Guru - Experienced User
Maybe a issue with the phone.
Besure your wired LAN cable speeds are good. If this and other wifi devices work well. Possible issue with this particular phone.
Any Wifi Neighbors near by? If so, how many
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
