QC91
Dec 17, 2019Aspirant
Slow WiFi 2.4 GHz on Orbi
We have an RBR50 with 2 Satellites we Just Started to have slow Speed on the 2.4 GHz WiFi only, we have had the RBR50 for just over 1 Year and have never had any Speed issues, we have not moved any...
QC91
Hi, Thanks for all the replies
What is the Mfr and model# of the ISP modem the NG router is connected too? Arris SURFboard SB8200 DOCSIS 3.1
What is the size of your home? Sq Ft? 1700, We have had the system up for just over a year and have not moved anything we can be sitting in front of the router a few feet but it does not help with the 2.4 GHz
Any Wifi Neighbors near by? If so, how many? Auto
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)Armor, Circle, Daisy Chain, are disabled
Dec 17, 2019Guru - Experienced User
Just checking the modem. Good here.
So if you turn OFF the RBSs and leave just the RBR online. Speeds are slow on 2.4Ghz?
What device are using to test 2.4Ghz?
Try setting manual channel on 2.4Hz to 1, 6 or 11.
