Phiniac
Sep 11, 2019Aspirant
Slow Wifi for mobile devices
ISP montana sky networks wireless broadband (dish to tower) paying for 50/6 getting 57/13 plugged directly to router router updated to latest firmware 2.3.5.30 Router is in center of house in offi...
- Sep 23, 2019
Ok...so it appears that speedtest.net and the speedtest app on android are not giving reliable results. Went to fast.com and it reported 56-59mb down. I'm paying for 50mb so it appears to be good. Don't think i'm going to use speedtest anymore, at least for wireless devices. Right now just tested again...
speedtest app for android 31mb down
fast.com on same android using chrome browser 57mb down
speedtest.net website on android using chrome (had to check "desktop site" in options) 48mb down
SPEEDTEST.NET SUCKS!!!
Sep 11, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM all together. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- PhiniacSep 11, 2019Aspirant
FURRYe38 wrote:What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. 30ish feet to the wifi backhauled satellite sounds about right. The wired satellite is closer to 50/60 feet. They are on opposite ends of the house with the main router in the middle of the house.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Currently 2.4 set to 11 and 5g is set to 36
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM all together. Under Advanced Tab/Advanced Settings/Wireless Settings I've tried variations of these settings but currently, yes, thats what they are already set to.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Can't find where to disable armor. Circle, daisy chain and ipv6 are disabled. I'll try disabling fast roaming and set the coexistence and report back shortly.- PhiniacSep 11, 2019Aspirant
unchecked the 20/40 coexistence but can't see where to set it to "40 only" as you suggested.
everything else is set as directed.
Phone's connection reports a rate of 650mbps but speedtest app is only getting 27.6 down 12.1 up.
- FURRYe38Sep 11, 2019Guru - Experienced User
Is the 1 wired RBS directly connected to the RBR or thru a LAN switch? Daisy chain should be disabled for this.
Do you get good speeds at the wired RBS?
Might try swapping the RBS placements around and see if problem follows or not as a troubleshooting step if needed.
FURRYe38 wrote:Is the 1 wired RBS directly connected to the RBR or thru a LAN switch? Daisy chain should be disabled for this.
It is connected thru an unmanaged netgear gigabit switch. As directed by you previously, daisy chain is disabled.
I could try this if needed. I just tried powering off the wifi RBS to see if the main router would provide better results when connected to it with a short 5ft distance and produced the same results.
