Audi4Rings
Jun 04, 2020Aspirant
slow wifi performance
Hello all, I'm hoping someone can provide some insight regarding my wifi speed at home. I recently upgraded my broadband speed from 300Mbps and Gigablast from Cox cable. I'm using Netgear CM...
- Jun 06, 2020
Any progress on this?
Jun 04, 2020Guru - Experienced User
Depending upon connection rates see at the device and design and support of wifi performances, you'll not see anything much over 400-500Mbps on wifi speeds tests on AC mode. Contact the Mfr to see what rates and performances your devices are designed for.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Wired LAN cable speeds should see near 900Mpbs on the down.
Audi4Rings
FURRYe38 wrote:Depending upon connection rates see at the device and design and support of wifi performances, you'll not see anything much over 400-500Mbps on wifi speeds tests on AC mode. Contact the Mfr to see what rates and performances your devices are designed for.
Thanks FURRYe38 but I'm not even getting half that speed is my concern. I get an avg of 200Mbps on all devices (mobile and laptop). Something is definitely off.
- Audi4RingsJun 04, 2020Aspirant
There are NOT checked by default. Do you recommend I check these?
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices Enable MU-MIMO Enable Fast Roaming - Audi4RingsJun 04, 2020Aspirant
I read your recommendation here:
https://community.netgear.com/t5/Orbi/Beamforming-and-MU-MIMO-Disabled-by-Default/m-p/1854327#M81196
- FURRYe38Jun 04, 2020Guru - Experienced User
Yes. Test with those enabled. You can disable afterwards if needed.
