Audi4Rings
Jun 04, 2020Aspirant
slow wifi performance
Hello all, I'm hoping someone can provide some insight regarding my wifi speed at home. I recently upgraded my broadband speed from 300Mbps and Gigablast from Cox cable. I'm using Netgear CM...
- Jun 06, 2020
Any progress on this?
Audi4Rings
FURRYe38 wrote:Depending upon connection rates see at the device and design and support of wifi performances, you'll not see anything much over 400-500Mbps on wifi speeds tests on AC mode. Contact the Mfr to see what rates and performances your devices are designed for.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Wired LAN cable speeds should see near 900Mpbs on the down.
Thanks FURRYe38 but I'm not even getting half that speed is my concern. I get an avg of 200Mbps on all devices (mobile and laptop). Something is definitely off.
Audi4Rings
There are NOT checked by default. Do you recommend I check these?
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices |
| Enable MU-MIMO |
| Enable Fast Roaming |
- Audi4RingsJun 04, 2020Aspirant
I read your recommendation here:
https://community.netgear.com/t5/Orbi/Beamforming-and-MU-MIMO-Disabled-by-Default/m-p/1854327#M81196
- FURRYe38Jun 04, 2020Guru - Experienced User
Yes. Test with those enabled. You can disable afterwards if needed.
