radamo's avatar
radamo
Apprentice
Aug 03, 2019
Slow wifi RBR50
I am running the latest firmware on my orbi.  2.3.5.30.  My wired connection is over 400Mb down and over 30 up.  Wifi used to be close to that.  Now running speedtest from my phone about 20 feet from my router and I am getting 80Mb down???  Just tried a few different channels and no real difference???
  • Retired_Member's avatar
    Retired_Member
    What kind of modem do you have?
        Retired_Member
        radamo wrote:
        Arris cable modem.
        and your previous router was...??
  • plemans's avatar
    has your phone been moved to the 2.4ghz band with orbi?  That'll reduce your speeds quite significantly.
    • radamo's avatar
      radamo
      Apprentice
      Results are both with Orbi RBR50 this current firmware vs. whatever the last few were.  Both with iPhone X and both on 5Ghz network.
      • plemans's avatar
        wifi isn't the best for doing speed testing as many factors can influence what speeds you get.
        If you hardwire into the router and extender with a pc, what speeds do you get?
        Have you tried changing wireless channels? Or doing a wireless channel scan to see if anythings interferring with the channel you're using?
        enabling/disabling beamforming, airtimefairness, mu-mimo?
