wolfiii
Aug 29, 2022Aspirant
slow wifi speed on both of my Orbi RBS50 satellites, usually around 40 to 60Mbps
I have two RBS50s hardwired to the RBR50 and when I test WiFi speeds on both it is usually 40 to 60Mbps, but anything plugged in hardwired to the RBS50 achieves 480 to 490Mbps. I am within 5 to 10 f...
Aug 29, 2022Guru - Experienced User
What device are you testing on and is that device connecting to the 2.4ghz or the 5ghz?
the 2.4ghz is a slower network and the 40-80mbps is right in line with its performance.
The 5ghz should hit 300+ speeds.
