wolfiii
Aug 29, 2022Aspirant
slow wifi speed on both of my Orbi RBS50 satellites, usually around 40 to 60Mbps
I have two RBS50s hardwired to the RBR50 and when I test WiFi speeds on both it is usually 40 to 60Mbps, but anything plugged in hardwired to the RBS50 achieves 480 to 490Mbps. I am within 5 to 10 f...
CrimpOn
Aug 29, 2022Guru - Experienced User
Assuming the same WiFi device was used to measure speed, how did you verify that the device was attached to each satellite during the test?
- wolfiiiAug 29, 2022Aspirant
I brought up the Orbi app and verified where the Iphone was connected
