TFlav
May 01, 2021Apprentice
Slow WIFI speeds on my rbr50 with ATT fiber
I resently got the BGW210 router from ATT as I read that it works best with my orbi rbr50. after getting everything set up, everyting was working great for a few days. Wired connection speed are comi...
May 01, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
TFlav
May 02, 2021Apprentice
I've already configured my routers. I have both wifi's disabled and put the router in IP Passthrough on my ATT Router. I have my orbi router in AP mode. My satellite is no more then 30 feet from my orbi router. My orbi firmware is up to date.
I followed these steps from this youtube video.
https://www.youtube.com/watch?v=OZz6E8Xk_Hs
If this is wrong can you guide me to a step by step guide on how to configure my setup?
- TFlavMay 03, 2021Apprentice
Square footage is approx. 3600 sq. ft.
