TFlav
May 01, 2021Apprentice
Slow WIFI speeds on my rbr50 with ATT fiber
I resently got the BGW210 router from ATT as I read that it works best with my orbi rbr50. after getting everything set up, everyting was working great for a few days. Wired connection speed are comi...
May 03, 2021Guru - Experienced User
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What WiFi devices are you using to speed test with?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
TFlav
May 05, 2021Apprentice
FURRYe38 I use ookla speedtest app.
I have no idea what channels I'm using or how to check them. I'm a noob when it comes this stuff. So if you could give me step by step instructions that will really help. I have no idea what beamforming, MIMO or WMM are. I really have no idea what you're asking me to check in the rest of the message you sent either. please be as specific as possible.
