TFlav
May 01, 2021Apprentice
Slow WIFI speeds on my rbr50 with ATT fiber
I resently got the BGW210 router from ATT as I read that it works best with my orbi rbr50. after getting everything set up, everyting was working great for a few days. Wired connection speed are comi...
TFlav
May 05, 2021Apprentice
when I looked under my 2.4ghz and 5 ghz it say current channels: N/A. There's a button that says scan for best channels.
May 05, 2021Guru - Experienced User
Ok, Most speed tests on iphones and pad will top out at around 400-500Mbps depending on device support on 5Ghz.
I recommend you find someone locally to help you with this. Friend or family member that can look this over and go over it with you.
- TFlavMay 05, 2021Apprentice
That was from my ATT router. Should I be looking on my orbi router?
