TFlav
May 01, 2021Apprentice
Slow WIFI speeds on my rbr50 with ATT fiber
I resently got the BGW210 router from ATT as I read that it works best with my orbi rbr50. after getting everything set up, everyting was working great for a few days. Wired connection speed are comi...
TFlav
May 05, 2021Apprentice
Ok I'll try and find someone I trust to help me with this.
TFlav
- TFlavMay 07, 2021Apprentice
Ok so now I can't even connect to my wifi. my satellite won't connect to the router. I noticed that the Satellite was showing a mangenta color when i was on my orbi app. I was trying to re-sync the satellite to my router when i notice that someone turned the satellite off. when I turned the satellite back on my wifi went out and I can no longer connect to my wifi and the satellite won't connect to the router anymore. i haven't tried doing any configurations to the router or satellite since I last reached out, as I waiting to hear back from a couple of friends that might be able to help. I'm just not sure why my wifi wouldnt be working. my desktops work just fine and they are connected to my orbi router. Also the wifi was working this morning(poorly but working), only when I turned my satellite back on did the wifi go out.
When I check on orbilogin.com it says that the Satellite is connected and that the backhaul is good. Both my router and satellite has the most recent FW.
Do I need to factory reset everything again?
- FURRYe38May 07, 2021Guru - Experienced User
If you have done a reset already then no you don't need to reset again.
Bring the RBS near the RBR, same room if you can. Try to sync the RBS using the back sync button on the RBR then on the RBS. Does the RBS sync correctly at all while in the same room as the RBR?
