nabeelm
Mar 31, 2020Follower
Slow wifi speeds Orbi RBR50
Hi Guys! My first post, so not sure if I am addressing this correctly or not! But Ive started to experience slow wifi speeds over the last few weeks. I have Virgin Media 350mbps using SuperH...
Anonymous
Mar 31, 2020if you'll do a search, you'll see that many have had problems Firmware v2.5.1.8
your best bet is to revert back to your previous version and STOP performing manual downloads
tspoon
Mar 31, 2020Aspirant
How do you revert back to the previous Firmware to see if it corrects the issue
- FURRYe38Mar 31, 2020Guru - Experienced User
Just download the prior version of FW files and manually apply them.
You should try a factory reset and setup from scratch before downgrading. This has helped others seeing problems.
Can try voxels FW aswell:
tspoon wrote:How do you revert back to the previous Firmware to see if it corrects the issue
- tspoonMar 31, 2020Aspirant
Seems complicated, not sure I can keep from screwing that up. I am only getting about 96 mdps down whcih is an issue correct? A Connecting directly to the RBR50, I get about 600 mpbs
Where are you seeing this 96Mbps speed at?
Wired or wireless?
Are you connecting with the RBR or RBS?
tspoon wrote:Seems complicated, not sure I can keep from screwing that up. I am only getting about 96 mdps down whcih is an issue correct? A Connecting directly to the RBR50, I get about 600 mpbs
