nabeelm
Mar 31, 2020Follower
Slow wifi speeds Orbi RBR50
Hi Guys! My first post, so not sure if I am addressing this correctly or not! But Ive started to experience slow wifi speeds over the last few weeks. I have Virgin Media 350mbps using SuperH...
tspoon
Mar 31, 2020Aspirant
How do you revert back to the previous Firmware to see if it corrects the issue
Mar 31, 2020Guru - Experienced User
Just download the prior version of FW files and manually apply them.
You should try a factory reset and setup from scratch before downgrading. This has helped others seeing problems.
Can try voxels FW aswell:
tspoon wrote:How do you revert back to the previous Firmware to see if it corrects the issue
- tspoonMar 31, 2020Aspirant
Seems complicated, not sure I can keep from screwing that up. I am only getting about 96 mdps down whcih is an issue correct? A Connecting directly to the RBR50, I get about 600 mpbs
- FURRYe38Mar 31, 2020Guru - Experienced User
Where are you seeing this 96Mbps speed at?
Wired or wireless?
Are you connecting with the RBR or RBS?
tspoon wrote:Seems complicated, not sure I can keep from screwing that up. I am only getting about 96 mdps down whcih is an issue correct? A Connecting directly to the RBR50, I get about 600 mpbs
- AnonymousMar 31, 2020
if you'll do a search, you'll see that many have had problems Firmware v2.5.1.8
