slow_wifi_speed
Mar 23, 2018Aspirant
Slow wifi speeds when using Orbi AC3000 (RBR50 and 2 RBS50) and Arris SB8200 Cable Modem
Hi, I have a very unique and frustrating issue which I am hoping to resolve. I don’t believe that I am the only one facing this issue so I hope my post will help others also. My current problem is; my...
Mar 23, 2018Guru - Experienced User
What version of FW is the system using currently?
I would suggest upgrading to the beta and retest again:
The first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.
New beta FW avaialble. Get it while its hot of the press:
Please perform a factory reset on the satellite and router and set up from scratch. Don't set up or touch QOS, Traffic Meter or Access Controls. Run a ethernet connected PC speed test first.
- slow_wifi_speedMar 23, 2018Aspirant
Thank you for the quick reply. My FW for all devices is v2.0.1.4
I have never performed a FW update. Is this hard to complete? and do I have to update each 3 devices seperately? Just looking for some assessment of the level of technical skills needed and time to perform the upgrade.
Thank you for your help.
- FURRYe38Mar 23, 2018Guru - Experienced User
Please review the linked information. IT will guide you thru doing a FW update.
I after the FW has been loaded, I recommend doing a factory reset on the router and Satellite(s) then set up from scratch.
