slow_wifi_speed
Mar 23, 2018Aspirant
Slow wifi speeds when using Orbi AC3000 (RBR50 and 2 RBS50) and Arris SB8200 Cable Modem
Hi, I have a very unique and frustrating issue which I am hoping to resolve. I don’t believe that I am the only one facing this issue so I hope my post will help others also. My current problem is; my...
Baris
Sep 11, 2018Tutor
Hi,
I'm also having problems with low wifi speed with the AC3000. I have a 1Gigabit plan and when using cable with the router, I can see speed rates on appr. 800mbit however when turning to wi-fi, the speed drops to appr. 200-250 mbit. I'm using the latest FW 2.1.4.16. Have tried with speedtest and bredbandskollen.se (swedish site) and get the same result. Please advise!
Sep 11, 2018Guru - Experienced User
Wifi speeds will not be attained any where near 900Mb. Max limitation on Wifi in ideal or optimal conditions are currently around 400-500Mb depending upon client side device HW design and support. You'll have to contact the Mfr of your devices to see what there actual wifi speed thruput is.
Baris wrote:
Hi,
- BarisSep 17, 2018Tutor
HI Furrye38 and thanks for the reply.
I've continued my tests and there's a remarkable inconsitency when it comes to performance. Over the last 2 days, my wifi speed has been around 60-70 mbit/s on a 1Gigabit plan. Did a factory reset which seemed to "solve" the issue and I could see speeds up to 500-600 mbit/s, however now it's back to 60 mbit and that can't be expected..
- FURRYe38Sep 17, 2018Guru - Experienced User
What are the wired speed test results after a couple of days?
What channels are you using? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- Num1willisDec 16, 2018AspirantDid you ever get it solved. I’ve had the same problem for the past year. Inconsistent speeds.
