PlatinumGoat
Dec 14, 2018Apprentice
Slow WiFi speeds
Hi everyone, I recently upgraded my broadband speed to 1gbps. Although I can achieve around 900mbps up/down with a direct cable connection to the router, I only managed to get around 400 plus mbps f...
- Dec 14, 2018
Yes you can disable Daisy Chain, if your on v210, put a check mark in the Daisy Chain box. Users have said v210 seems to work in reverse on this version of FW.
Yes, Enable Beamforming. If you have MIMO supporting devices MIMO can be enabled. If, not, keep it disabled. Leave CTS values if your not having problems with devices connecting to the Orbi wifi.
PlatinumGoat wrote:
Thanks for the reply. I however find it strange that official tech support from NG find my speeds too slow. If not, they wouldn't recommended several changes like turning daisy chain off (I only have one satellite), turning on implicit beam forming, turning on mu-mimo and also adjusting the CTS/RTS to 2307 instead of 2347. What do you think?
PlatinumGoat
Dec 14, 2018Guru - Experienced User
