Cameron49
Mar 16, 2021Tutor
Slow wifi with Orbi RBR20 and satellites
One, last ditch attempt before these go back to the store. I have Gig ethernet to my home. A wired connection gives me 973 Mbps download. Before Orbi I could get 900+ Mbps wifi but the kids complaine...
Mar 16, 2021Guru - Experienced User
What devices are you using to test speed on wifi?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
FYI, you not see anything near 900Mpbs on wifi on Orbi AC. Max speeds for most devices cap out at around 400-500Mpbs on 5Ghz AC.
Cameron49 wrote:One, last ditch attempt before these go back to the store. I have Gig ethernet to my home. A wired connection gives me 973 Mbps download. Before Orbi I could get 900+ Mbps wifi but the kids complained about the coverage to the attic and second floor bedrooms. So I bought Orbi. Now I get 90 Mbps. The Hitron cable modem/router has all wireless turned off and the Orbi is set to AP mode. I have read most of the postings about this and I have tried most of the settings. Has there been any progress on resolving this issue?
Thanks.
vajim
Mar 16, 2021Master
FURRYe38 wrote:What devices are you using to test speed on wifi?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Thanks.
Help me out here. Why can't we allow the original poster asnwer my question before you post? Should I delete my question?
