tshaw8261
Jan 04, 2019Aspirant
Slow Wifi
I installed an Orbi RBR20 wifi system and having horrible porblems w/ very slow wifi speeds. The box states supports up to 2gig, that seems far from the truth. I was getting 380mbps on Iphone 10, a...
Jan 04, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
tshaw8261 wrote:
I installed an Orbi RBR20 wifi system and having horrible porblems w/ very slow wifi speeds. The box states supports up to 2gig, that seems far from the truth. I was getting 380mbps on Iphone 10, and over 640mbps on MacPro, all wireless on old Uverse box. Bought Orbi for more range. Barely getting 200mbps now on all devices. This is a huge problem, as I have gigabyte service, and getting 980+mbps to modem. Have tried all options given by so called support desk. Sounds like they are reading from a script. Can anyone please help, or have any suggestions. I like the coverage, but can't keep a product that kills my speeds. Thanks
