tomas_arnold
Feb 14, 2022Aspirant
slow wifi
when conncected i get 215 MB down but when any device connected max down is 18 MB that is the device within 6 inches of the access point. do not know why or what settings are incorrect. Router Firmwa...
Feb 14, 2022Guru - Experienced User
A bit more details is needed.
1. what modem/gateway is the orbi connected to?
2. what wired speed do you get?
3. what is the speed over 2.4ghz?
4. what is the speed over 5ghz?
5. what device are you testing on and what site/app are you speedtesting on?
tomas_arnold
1. what modem/gateway is the orbi connected to? the provided AP20 from the cable company
2. what wired speed do you get? wired i get 224.36 down and 11.61 up MB
3. what is the speed over 2.4ghz? 36.80 down and 11.32 up MB
4. what is the speed over 5ghz? 41.46 down and 11.67 up MB
5. what device are you testing on and what site/app are you speedtesting on? www.speedtest.net
