tosehee
Oct 13, 2018Aspirant
Slow wired download speed with AT&T Gigabit
I have AT&T Gigabit, and if I connect directly to the modem, I get 900mbps down/up. However, if I connect through Orbi (wired), the upstream remains the same, but the downstream cuts in half.
It hovers around 500 mbps at the most. I have no clue why this is happening. I tried IP passthrough, AP or Router Mode. Disabled all packet filters and advanced firewall rules in Modem. But nothing helps.
Is this an issue with Orbi?
- Retired_Member
What is your setup? Modem, Orbi? Or some type of modem/router or another stand alone router?
- toseheeAspirant
at&t router -> orbi rbr 50
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
