tosehee
Oct 13, 2018Aspirant
Slow wired download speed with AT&T Gigabit
I have AT&T Gigabit, and if I connect directly to the modem, I get 900mbps down/up. However, if I connect through Orbi (wired), the upstream remains the same, but the downstream cuts in half.
I...
tosehee
Tried AP mode with connected to LAN Port. The download speed is exactly same.....
Any other idea?
Oct 14, 2018Guru - Experienced User
I would contact NG support and ask for additional help and information. Others have reported getting 900Mb on the down. Possible either there is a incompatbility between the ISP modem and the Orbi router or the router could be faulty..
- toseheeOct 15, 2018Aspirant
Do you have a reference to these thread?
- FURRYe38Oct 16, 2018Guru - Experienced User
I don't, been a while since they were posted. Please contact NG support and go from there.
You can check the Recommendation links to the left side of this thread to see if anything is listed there or do a search.
