jwkidd3
Jun 28, 2020Follower
Slow Wired Speeds RBK50
This is really frustrating. The best speed I can get on a wired connection at the router is 539 up/495 down
| Firmware Version | V2.5.1.16 |
| GUI Language Version | V1.0.0.375 |
I think I have tried everything. Here is what I have done so far:
I have 1Gigabit from ATT. At the router I am getting over 900 up/900/down. Here are my test results:
- sattelite directly to the ATT Modem via ethernet: 700 up/892 dn
- netgear 8 port switch directly to the ATT Modem: 700 up/913 dn
- sattelite connected to orbi router - ethernet backhaul: 442 up/510 dn
after resets 1 & 2. No change in speeds.
After changing to AP mode. No chanve in speeds.
After disabling daisy chain. No change in speeds.
FYI best wireless speeds 1 ft from Orbi Router is (5g connection) 398 up/290 dn
Wifi speeds connecting to ATT Wifi: 877 up/910 dn
Something is off with the Orbi router. Unless there is something that I am missing this thing is going back.
1 Reply
Having a router in front of the Orbi will cause problems. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would factory reset the RBR and setup fron scratch. Do not enable Armor, Access Controls, Circle, QoS or Traffic Meter. Speed test with a wired PC using Ooklas installable speed test app.
Orbi does work for near 900Mpbs however depends on ISP Modem. Gatway routers are NOT recommended.
You can also try this:
