Tbsteph
Dec 09, 2020Star
Slow Wireless - Restart Required
I have owned the RBR 50 with one satellite for about 3 years. It is connected via 200Mps service from Spectrum iand is n router mode. I have lived through probably 10 firmware updates. Yet, to this ...
Dec 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
vajim
Dec 09, 2020Master
Any Wifi Neighbors near by? If so, how many?:smileyhappy:
