Tbsteph
Dec 09, 2020Star
Slow Wireless - Restart Required
I have owned the RBR 50 with one satellite for about 3 years. It is connected via 200Mps service from Spectrum iand is n router mode. I have lived through probably 10 firmware updates. Yet, to this ...
Dec 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Tbsteph
Dec 09, 2020Star
I expected this response. You or someone posts the same thing whenever wireless speed is questioned. Anyway, I have already implemented all of the suggestions made regarding enabling disabling various settings. Firmware is current 2.7.1.60. As mentioned in first post, none of the suggestions make any difference. No interference from neighbors, etc. This is the second home I have set-up with the RBR50 with the exact same problem. The best analogy I can come-up with is the router becomes constipated. Restarting is the only thing that clears the issue. Forgive my venting. I realize this is a user forum and appreciate other users piping in with their experience.
- vajimDec 09, 2020Master
"the router becomes constipated."
how old is it...Orbi???
and there are lots of complaints about 2.7.1.60.
do a search here....good luck
- FURRYe38Dec 09, 2020Guru - Experienced User
Understand the frustrations too.
v2.7 can be a mixed bag of good and not well.
If v2.7 doesn't seem to work well, you might downgrade to v16.
Have you reset the system after any FW update and the problem still continues?
Do you have any Armor, Circle or IPv6 enabled?
Tbsteph wrote:I expected this response. You or someone posts the same thing whenever wireless speed is questioned. Anyway, I have already implemented all of the suggestions made regarding enabling disabling various settings. Firmware is current 2.7.1.60. As mentioned in first post, none of the suggestions make any difference. No interference from neighbors, etc. This is the second home I have set-up with the RBR50 with the exact same problem. The best analogy I can come-up with is the router becomes constipated. Restarting is the only thing that clears the issue. Forgive my venting. I realize this is a user forum and appreciate other users piping in with their experience.
Firmware?
how do you get your current firmware?
