msunshine
Sep 15, 2019Tutor
Slow wireless download speed in AP mode
I'm hoping someone can help me troubleshoot this issue. I currently have gig service via Centurylink and also through Xfinity. I'm comparing the 2 services for awhile and deciding which is better...
msunshine
Sep 15, 2019Tutor
Orbi firmware is v2.3.5.30.
Since the Orbi is in AP mode, wireless speed tests are being done. There are zero issues with the Orbi via wired.
Satellites are 40 feet apart and are connected via cat5.
Have done the factory reset. Issue persists.
Orbi connected directly to the modem. No switch inbetween.
The issue is AP mode. Everything works in router mode. Whenever the Orbi is in AP mode the download speeds suffer. The behavior is reproduceable using both the Xfinity router and the CL router. Same with an EdgeRouter 4. Whenever the Orbi is in AP mode is when issues arise.
I've messed with all of the wireless settings (channels, beamforming, 20/40, etc). Nothing has worked. I'm tempted to buy a new Orbi just to see if it is a hardware issue or something because it makes no sense that simply being in AP mode would cause this issue.
Sep 15, 2019Guru - Experienced User
After a reset, and configure for AP mode, try testing just with the RBR only while the RBS are turned OFF.
Possible issue with the Orbi you got from Amazon...
- msunshineSep 15, 2019Tutor
We're fairly remote so no neighboring wifi interference.
I'll try a factory reset again and leave the satellites off.
I've had the router and 2 satellites for about 3 years now, maybe longer. I remember I had issues with AP mode when I first set up the Orbi and switched to router mode to get around those issues. I'm thinking it is a hardware issue or something. Maybe I can pick up a used/cheap rbr50 on craigslist or something to test that theory.
- FURRYe38Sep 15, 2019Guru - Experienced User
Ah, ok, if this has been a problem since...could still be on going and a HW issue. Let us know.
