eracet's avatar
eracet
Slow wireless speeds 5ghz
RBR40 Base. 2 x RBK40 Satellites   I just got Gig internet and testing speeds available on my devices. The order goes Modem > Orbi > Networks switch. I get around 900 on my wired connections. B...
  • krlesch's avatar
    Jul 17, 2022
    I hope that this helps - I found a website that explains "what to expect" from various devices when connected to a gigabit connection.
    Go to https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi and expand the three (3) sections:
    1) Mobile devices (Wi-Fi)
    2) Computers (Wi-Fi)
    3) Computers (Ethernet or USB adapter to Ethernet)
    I understand that the website is for Google Fiber, but the information it provides is useful regardless of ISP.
    Specifically under the "MOBILE DEVICES (Wi-Fi)" section you will see that the most that you will get from a mobile device using 802.11ac is around 390Mbps.  So what you are describing is your Orbi providing the speed it is designed to provide.  Hope that this helps set expectations.
