eracet
Jul 16, 2022Aspirant
Slow wireless speeds 5ghz
RBR40 Base. 2 x RBK40 Satellites I just got Gig internet and testing speeds available on my devices. The order goes Modem > Orbi > Networks switch. I get around 900 on my wired connections. B...
- Jul 17, 2022
I hope that this helps - I found a website that explains "what to expect" from various devices when connected to a gigabit connection.
Go to https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi and expand the three (3) sections:
1) Mobile devices (Wi-Fi)
2) Computers (Wi-Fi)
3) Computers (Ethernet or USB adapter to Ethernet)
I understand that the website is for Google Fiber, but the information it provides is useful regardless of ISP.
Specifically under the "MOBILE DEVICES (Wi-Fi)" section you will see that the most that you will get from a mobile device using 802.11ac is around 390Mbps. So what you are describing is your Orbi providing the speed it is designed to provide. Hope that this helps set expectations.
krlesch
Jul 17, 2022Star
