Vcorr90
Nov 14, 2018Aspirant
Slowed download speeds after fiber installation
I had ATT fiber internet installed at my house and after installation was getting over the advertised download and upload speeds of around 120mb on the Orbi speed test, both over WiFi and Ethernet thr...
Nov 14, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- Vcorr90Nov 14, 2018AspirantI have tried everything. My question is why would it slow speeds after a week of working fine with no change. Especially since it’s slow both wired and wireless while the modem Ethernet has full speed. The att gateway is a pace 5268AC
- FURRYe38Nov 14, 2018Guru - Experienced User
Your ISP modem is a gateway. Possible cause here.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop or https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-pointWould also need to fill in answers to some of the questions presented as well...
- Vcorr90Nov 14, 2018AspirantMost current firmware is being used. The home is about 2000 sqft. The channel is set to auto but have tried the others you mentioned as well. As far as setting up the router, the gateway right now has WiFi channels turned off because there is no true bridge mode so it’s set up exactly as your second combination. I haven’t yet tried setting it up as an access point but will try that next.
