Vcorr90
Nov 14, 2018Aspirant
Slowed download speeds after fiber installation
I had ATT fiber internet installed at my house and after installation was getting over the advertised download and upload speeds of around 120mb on the Orbi speed test, both over WiFi and Ethernet thr...
Vcorr90
I have tried everything. My question is why would it slow speeds after a week of working fine with no change. Especially since it’s slow both wired and wireless while the modem Ethernet has full speed. The att gateway is a pace 5268AC
Nov 14, 2018Guru - Experienced User
Your ISP modem is a gateway. Possible cause here.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop or https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Would also need to fill in answers to some of the questions presented as well...
