Bmockeg
Oct 23, 2019Aspirant
Slower speed from modem to Orbi
Have gigabit internet through Suddenlink. I use an Arris SB6190 and have had a tech come out and confirm I am pulling 970Mbs to the modem. On Orbi the fastest speed test I have achieved is 768Mbs usin...
Oct 23, 2019Guru - Experienced User
Try ooklas installable speed test app instead of the browser based site.
Testing with a wired PC? Try a different wired PC to compare.
Bmockeg
Oct 25, 2019Aspirant
Ok, finally had a moment to test and I tried plugging my cat6 cable to modem. Tested 920Mbs. If I plug cable to ORBI I get only 750Mbs still. Tried several speed test sites and all the same.
- BmockegOct 26, 2019AspirantAnyone have any idea or do I need to get a different router?
- plemansOct 27, 2019Guru - Experienced User
I've read on here of some orbi's not able to fully max out gigabit connections. Mine does. Not sure why yours doesn't or if its an issue of the version of firmware you're on. You can try downgrading. I'm not sure at what version it auto updates though. I know that auto update feature has been removed but not sure when.
I'd try a downgrade and reset and see if it works.
do you fully max out your gigabit connections? the only time I've found that I even come close is for speedtesting. thats it. (not saying its not good to have and the device should support it)
