Drake0508
Apr 06, 2017Star
Smart TV Connection
Hey everyone, I have a smart TV that is approximately 10 feet from my satellite. For some reason it continues to try and connect to the 2.4 GHz channel on my Orbi. There is a lot of lag in bufferin...
Drake0508
Apr 07, 2017Star
I have it plugged into the hdmi port and there is a power plug attached at the end. Is that what you mean?
- GleneeApr 08, 2017Apprentice
The power has to be there. I was talking about the short extender cable that comes in the box, the extender cable is used primarly for tight fit to certain TV's.
